1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: side-effect of malloc() in startup file
To: "Peregrine M. McGehee" <[email protected]>
Cc: [email protected]
Date: Tue, 30 Jul 2002 19:37:20 +0200
Hi Peregrine,
Peregrine M. McGehee wrote:
The vxWorks tShell crashes after calls to both malloc() and
iocInit within a st.cmd have been traced to the drvTS.c TSinit() routine that is called within iocInit. The environment is Power PC; VxWorks 5.4; EPICS R3.13.5 and requires definition
of local synchronized timestamp support routines
(http://www.aps.anl.gov/asd/controls/hideos/GTS.html).
This is a consequence of insufficient (none!) range checking for access within the TSdata.event_table array of struct timespec
allocated in TSinit(). The quick patch is to always have an
ErSyncEvent() function that returns an event number less than
the return value of ErHaveReceiver() when supplying local timestamp support. The harder correction is to rewrite drvTS!
....which is underway. I hope to fix some other problems, too.
The progress has not been as fast as I had hoped (busy with other
things) but the first rewrites (that can be published) should be ready within a month or two.
best regards,
			Timo
Timo Korhonen PSI (Paul Scherrer Institut)
CH-5232 Villigen PSI
tel + 41- 56 3103262 fax + 41 - 56 310 3151
e-mail: [email protected]
side-effect of malloc() in startup file Peregrine M. McGehee
Re: side-effect of malloc() in startup file Peregrine M. McGehee
Prev: Re: side-effect of malloc() in startup file Peregrine M. McGehee
Next: Re: How do I use registryFunctionAdd Rozelle Wright
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: seq-1.9.6-beta redux Laznovsky, Michael
