Appologies if you've already seen this message from Peregrine twice, but
some people haven't received a copy at all yet. - Andrew
-------- Original Message --------
Subject: Re: "moving" N to 1 compression records
To: [email protected]
Here's a proposal for an extension to the compression
record:
o add a field "NP" that controls the rate that the
N-to-1 computations are performed. The record would
update min, max, median, or average (mean) every
NPth time it was processed.
o for backwards compatibility, the default value of
NP would be 0. This would be equivalent to NP=N.
o the behavior I need is obtained by setting NP=1.
Although the easiest way forward is to use an
existing compression record configured as a circular
buffer and feed it into an ANL waveform analysis
record (courtesy of John Maclean). This record computes
max, min, peak to peak, mean (but not median),
mean abs deviation, variance, standard deviation, and
FWHM in one go.
- Peregrine
Peregrine M. McGehee [email protected] (505) 667-3273
Sloan Digital Sky Survey / Spallation Neutron Source
MS H820, Los Alamos National Laboratory, Los Alamos, NM 87545
Testing tech-talk Andrew Johnson
FW: Application for port-number (5064-5065) Jeff Hill
<2002>
2025
2026
"moving" N to 1 compression records Peregrine M. McGehee
<2002>
2025
2026
