1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Passing large arrays over channel access with R3.14b2
To: "'S. Joshua Stein'" <[email protected]>
Cc: "EPICS-tech-talk" <[email protected]>
Date: Wed, 14 Aug 2002 08:11:56 -0600
Both client library and server must be running EPICS R3.14, and
EPICS_CA_MAX_ARRAY_BYTES must be set appropriately for both when they
initialize.
Jeff
> -----Original Message-----
> From: S. Joshua Stein [mailto:[email protected]]
> Sent: Wednesday, August 14, 2002 6:51 AM
> To: [email protected]
> Subject: Passing large arrays over channel access with R3.14b2
> Greetings,
> lient Xterm. When I attempt to run an SDDS tool to read the waveform,
I
> get the following error message:
> CA.Client.Diagnostic..............................................
>     Message: "The array or data structure specified will not fit in CA
> message buffer"
> The environment variables on my ioc are as follows:
> epics> epicsPrtEnvParams
> EPICS_AR_PORT: 7002
> EPICS_CAS_BEACON_ADDR_LIST is undefined
> EPICS_CAS_INTF_ADDR_LIST is undefined
> EPICS_CAS_SERVER_PORT is undefined
> EPICS_CA_ADDR_LIST: 164.54.189.255
> EPICS_CA_AUTO_ADDR_LIST: YES
> EPICS_CA_BEACON_PERIOD: 15.0
> EPICS_CA_CONN_TMO: 30.0
> EPICS_CA_MAX_ARRAY_BYTES: 512000
> EPICS_CA_REPEATER_PORT: 5065
> EPICS_CA_SERVER_PORT: 5064
> EPICS_CMD_PROTO_PORT is undefined
> EPICS_IOC_LOG_FILE_COMMAND is undefined
> EPICS_IOC_LOG_FILE_LIMIT: 1000000
> EPICS_IOC_LOG_FILE_NAME is undefined
> EPICS_IOC_LOG_INET is undefined
> EPICS_IOC_LOG_PORT: 7004
> EPICS_TIMEZONE: CUS::360:033102:102802
> EPICS_TS_NTP_INET is undefined
> Any ideas?
> S. Joshua Stein
> APS/ASD - Controls
> 630-252-4105
> [email protected]
Passing large arrays over channel access with R3.14b2 S. Joshua Stein
Prev: Large arrays over CA - attempt #2 S. Joshua Stein
Next: Re: alarm handler john sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Passing large arrays over channel access with R3.14b2 S. Joshua Stein
Next: Large arrays over CA - attempt #2 S. Joshua Stein
