On Monday, August 19, 2002, at 08:52 AM, S. Joshua Stein wrote:
I would like to set a (global) debugging variable which is part of my
device
support running on a solaris IOC (3.14b2). In the vxWorks world, I
would just
type:
deviceDebugVar=1
This, however, won't work with iocsh. Does anyone know if/how I can
gain access
to these variables?
Non-vxWorks IOCs don't have access to the executable symbol table (at
the moment) so this trick of assigning to variables doesn't work. About
the only thing I can suggest for now is to register a command to set the
variable:
/* setDebug */
static const iocshArg setDebugArg0 = { "level",iocshArgInt};
static const iocshArg * const setDebugArgs[1] = {&setDebugArg0};
static const iocshFuncDef setDebugFuncDef = {"setDebug",1,setDebugArgs};
static void setDebugCallFunc(const iocshArgBuf *args)
deviceDebugVar( args[0].ival);
Then, somewhere in your device initialization, register the command:
iocshRegister(&setDebugFuncDef,setDebugCallFunc);
Or, you can use a C++ static constructor to register the command for you
when the application starts. For example,
class SetDebugRegister {
public:
SetDebugRegister()
{ iocshRegister(&setDebugFuncDef,setDebugCallFunc); }
static SetDebugRegister setDebugRegisterObj;
Eric Norum <[email protected]>
Department of Electrical Engineering
University of Saskatchewan
Saskatoon, Canada.
Phone: (306) 966-5394 FAX: (306) 966-5407
- Re: Access to device support debugging vars via iocsh (3.14b2) Eric Norum
- Access to device support debugging vars via iocsh (3.14b2) S. Joshua Stein
Re: Capfast Symbol for Motor Record Benjamin Franksen
<2002>
2025
2026
<2002>
2025
2026
