1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: subRecord fix
To: Till Straumann <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 21 Aug 2002 09:45:11 -0500
It's just that it doesn't seem to make much sense to pass the
'process' pointer out there - or do I miss something essential here?
I believe it's there for subroutines that want to cause asynchronous processing - if the user subroutine sets psub->pact true before returning because of a background I/O operation, it will need to call the record's process() routine again when that I/O operation is complete. Passing it into the init subroutine is simpler for the user than requiring them to look up the process routine than using a construct that may at one time have been
(((struct rset*)psub->rset)->process)(psub);
which is a bit ugly and complicated if someone is new to C programming. The cast is no longer needed, but it might have been back in the old GTACS days.
- Andrew
Edsger W. Dijkstra, 1930-2002: "The use of COBOL cripples the mind;
its teaching should, therefore, be regarded as a criminal offence."
Re: subRecord fix Marty Kraimer
subRecord fix Till Straumann
Re: subRecord fix Andrew Johnson
Prev: Siemens/Profibus Drivers Robby Tanner
Next: RE: Lab view <-> EPICS David H. Thompson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: subRecord fix Andrew Johnson
Next: Re: subRecord fix Marty Kraimer
