1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: JCA thread safety
To: Epics Tech-Talk <[email protected]>
Date: Wed, 04 Sep 2002 17:11:11 -0400
We are using JCA within our accelerator framework. Has anyone dealt with thread safety issues relating to JCA? In particular, I am concerned with switching between asynchronous and synchronous modes of PendEvent. Sometimes we would like to write values immediately, while other times we would like to package changes in a single batch. These operations may take place concurrently in different threads.
The solution that we are considering here is to leave PendEvent in synchronous mode and write a higher level wrapper to coordinate batch writes. For example, value requests could be registered with the coordinator. The user then sends a request to push the results to the server and the coordinator wraps requests into a single pend event. In order to prevent conflicts with other threads, we would have to provide a lock to synchronize the pend events.
Has anyone already built such a solution? Is there a mechanism to use JCA in a thread safe way? Are there plans for a thread safe version of JCA in the future?
Additionally, it seems that within PendEvent.java, the variable m_exit should be declared volatile to ensure that the while loop in the run() method exits immediately when exit() is called.
thanks,
-tom pelaia
Tom Pelaia
SNS Project, 701 Scarboro Road, MS-6473, Oak Ridge, TN 37831
phone: (865) 574-6421, fax: (865)574-6617
RE: JCA thread safety Jeff Hill
Prev: Making Records Invisible Susanna Jacobson
Next: Waveform Analysis Record Susanna Jacobson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Making Records Invisible Ned Arnold
Next: RE: JCA thread safety Jeff Hill
