1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Getting Alarm Handler (1.2.9 or 1.2.10) to write to ACKT field
To: Dayle Kotturi <[email protected]>
Cc: Janet Anderson <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Fri, 6 Sep 2002 10:27:40 +0200
Hi Dayle, hi Janet!
>>>>> "Dayle" == Dayle Kotturi <[email protected]> writes:
  > Hi Ralph,
  > Thanks for your help. You were right.
  > As you can see [...]
Bingo!
So it was a good guess. (And: Thanks, Janet, for good error messages...)
  > Now, I just need to dream up a solution...
  > I think this means running alh as a "special user" who has the
  > privilege to write to all the dbs, and then write a script to change
  > from the shiftleader account to the "special user", all transparent
  > to the shifter.
  >    (...several hours later...)
  > But the use of a "special user" to run the alh still has a problem to
  > solve in that the shifter will be popping up dm panels via the 'P'
  > buttons as "special user" and would be able to press buttons which are
  > normally forbidden (to shifter account). It's like now I need to separate the
  > rules to write to ACKT  from the rules to write to the other fields...
No. Don't do that. You will mess up your EPICS base installation, always
have to re-patch these things when switching to a new version of base,
get nasty answers on tech talk that you are on your own since you
started screwing around with base ... all the good things.
I even find the "special user" approach in this case too complicated and
too painful to maintain.
Why not:
 o Leave the existing user and stuff as it is.
 o Leave the existing Gateway as it is.
 o Run a second Gateway on the gateway host that allows write access for
   the user/host that the alh runs under. This second Gateway runs using
   a non-standard CA server port. Since this will be used by alh only,
   the configuration could be simple.
 o The alh processes are started from a wrapper script with a special
   setting of EPICS_CA_ADDR_LIST that makes them use the special
   alh-Gateway which allows acknowledging alarms and writing the ACKT
   fields.
 o The "P" entries that start dm panels from alh are resetting the
   EPICS_CA_ADDR_LIST to the standard value (i.e. unsetting it?). This
   can be done either directly in the alh config or by another wrapper
   script. Thus the panels use the normal Gateway with restricted
   access.
 o Anyone who is starting dm panels manually will get the usual setting
   with the restricted access. You would have to know the special port
   number and set EPICS_CA_ADDR_LIST accordingly to be able to start
   panels with write access. So for a trusted system ... this is still
   bad, but not grossly negligent.
I would prefer generic script wrappers to change the settings, since
these are easy to maintain: changes are done in one place - without a
need to restart the alh processes.
Hope this helps,
Ralph
Prev: RE: Getting Alarm Handler (1.2.9 or 1.2.10) to write to ACKT fiel d Rock, Judith E.
Next: Re: Making Records Invisible Andreas Luedeke
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Getting Alarm Handler (1.2.9 or 1.2.10) to write to ACKT field Ralph . Lange
Next: medm/dm2k executable for Windoze Rarback, Harvey
