1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: "bad UDP msg ..." error message
To: <[email protected]>
Date: Mon, 9 Sep 2002 12:22:02 +0200 (MEST)
Hi all,
I began to test SBS PC6 embedded computer. It has PENTIUM compatible CPU.
There is BSP for this target for Tornado II. I use R3.13.6 Epics release.
To build Epics I added file CONFIG.Vx.sbs_pc6 derived from CONFIG.Vx.pc486
just by replacing appropriate compilation options (taken from BSP).
This file looks like:
# Created by Korobov for SBS PC6
# CONFIG.Vx.sbs_pc6
# This file is maintained by the EPICS community.
# Vx GNU cross compiler suffix
CMPLR_SUFFIX = 386
# For Vx directories of form:
#   $(VX_DIR)/$(HOST_ARCH).$(ARCH_CLASS)/bin
ARCH_CLASS = sbs_pc6
ARCH_DEP_CFLAGS = -DCPU=PENTIUM -mpentium -DCPU_VARIANT=PENTIUM
ARCH_DEP_CXXFLAGS += -x 'c++'
ARCH_DEP_CFLAGS +=   -fno-builtin -fno-defer-pop
Epics core was built successfully. I created some test database and
downloaded it into the IOC. From IOC side it seems to work OK.
But when I try to access any records from outside after starting any
CA clients I get messages (on client side):
.../iocinf.c: bad UDP msg from epicsPC20.desy.de:5064
What could be the cause of such behaviour.
Thanks in advance for any help or ideas,
V.Korobov
RE: "bad UDP msg ..." error message Jeff Hill
Prev: xy542 and koDevLib Allan Honey
Next: CA problem Pedro Gigoux
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: "bad UDP msg ..." error message Jeff Hill
