1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA problem
To: "'Allan Honey'" <[email protected]>
Cc: "'Al Conrad'" <[email protected]>, "'EPICS Tech-Talk'" <[email protected]>
Date: Mon, 9 Sep 2002 17:02:13 -0600
Alan,
A frequent cause of this type of problem occurs when the
client is off subnet from the server, the client can reach
the server via the EPICS_CA_ADDR_LIST, but the client does
not see the server's beacons (because of how the server's
beacon address list is configured).
If the client does not find its PV after about 15 min then
it stops searching altogether until it see a beacon anomaly
( a significant change in a server's beacon ).
Of course the primary cause of these problems is that directed
broadcasts do not cross routers well. The solution in the future
may be to use multicasting.
Another solution is to use the CA gateway to reach off subnet
servers.
The R3.14 program casw can be used to monitor server beacon
anomalies.
Jeff
> -----Original Message-----
> From: Allan Honey [mailto:[email protected]]
> Sent: Monday, September 09, 2002 1:20 PM
> To: Jeff Hill
> Cc: Al Conrad; 'EPICS Tech-Talk'
> Subject: CA problem
> Aloha
> We at Keck are also having what appears to be CA problems.
> In our case a client may lose connection to a subset of its
> open channels. The connections never restore and the client
> must be restarted. If one starts other clients, which connect
> to the same channels, that new client has no problems whilst
> the original client continues to be disfunctional.
> This problem affects various systems running on different
> SUN workstations at different times. I am currently using
> a network snooping tool to try understand what is occurring.
> I am unsure if the problem is in CA repeater or the servers in the
> realtime systems but I suspect the repeater. Of course I am fairly
> ignorant of the CA repeater. The occurrence is very infrequent so
> it is hard to force the problem in order to study it.
> If anyone has any experience with this problem or tools, which
> may help, please give me a yell.
> Allan
CA problem Allan Honey
Prev: CA problem Allan Honey
Next: Re: CA problem (Pedro Gigoux) Bernd Schoeneburg
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
