1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Recommendations for Power PC VME cards
From: "J. Frederick Bartlett ([email protected])" <[email protected]>
To: Dennis Armstrong <[email protected]>
Cc: [email protected], [email protected]
Date: Thu, 19 Sep 2002 14:16:28 CDT
> We are considering an upgrade to our systems to use the Power PC range
> of VME CPU cards .  So the  question is  which VME CPU cards do EPICS
> users  use?
> Which are most compatible with the EPICS software?
> thanks for the replies
> regards
Dennis,
  The Fermilab D0 experiment successfully uses MVME2301, MVME2304, and
MVME2604 processor boards -- we have ~100 PPC processors in the D0
control system. Depending upon your application, there may be other
MVME-series PPC boards that would better suit your purposes (i.e. a
better performance/price ratio). Keep in mind that these boards can
not be field-upgraded to add memory; so, when you estimate your memory
requirements, allow for sufficient expansion -- EPICS data structures
tend to be large.  I usually purchase boards with at least twice the
memory that I estimate will be initially required.
  We also have MVME162 processors (M68K family) and the same C and C++
source code builds for both processor families (with one or two
conditional sections).
						Fritz Bartlett
RE: Recommendations for Power PC VME cards David H. Thompson
Recommendations for Power PC VME cards Dennis Armstrong
Prev: re: simulation mode Laznovsky, Michael
Next: Re: old/new MVME-177 compatability Graham Waters
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Recommendations for Power PC VME cards Dennis Armstrong
Next: RE: Recommendations for Power PC VME cards David H. Thompson
