1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: FW: Some StripTool files - tiny SLAC modification
To: "'Kenneth Evans, Jr.'" <[email protected]>
Cc: Tech-Talk <[email protected]>
Date: Tue, 01 Oct 2002 13:55:54 -0700
Ken,
I recently made similar changes and sent the changes to DESY and TJNAF - the keepers of the forked code of which we know. I added default .cnf and .dat, and use environment variables to point to default directories.
I hope these ideas (and very minor mods) are useful to you.
/Ron Chestnut
"The direct use of force is such a poor solution to any problem, it is generally employed only by small children and large nations."
-David Friedman
-----Original Message-----
Sent: Wednesday, August 28, 2002 2:50 PM
To: Chris Larrieu (E-mail); Matthias Clausen (E-mail 3)
Cc: Chestnut, Ronald P.; Allison, Stephanie
Subject: Some StripTool files - tiny SLAC modification
Dear Chris and Matthias,
Please find enclosed four files from the StripTool:
Strip.c - few lines to support separate DATA storage directory
StripDialog.c - few lines to use env variable for CONFIG directory
StripDefines.h - few lines to support a default DATA filename extension
Makefile.Host - Two lines to set the default CONFIG filename and DATA filename extensions.
The two new env variables are STRIPCONFIGFILES and STRIPDATAFILES. If these have values, they are the default CONFIG and DATA locations; if they have no value, the behaviour is as before (current directory for both).
I know we are forked, most probably from both of you. This is my poor man's solution to unforking.
/Ron Chestnut
-David Friedman
Attachment: Strip.c
Description: Binary data
Attachment: StripDialog.c
Attachment: StripDefines.h
Attachment: Makefile.Host
Prev: RE: Strip Tool Maintenance Laznovsky, Michael
Next: Re: Strip Tool Maintenance Christopher Larrieu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Caveat: vxStats Ralph . Lange
