1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Caveat: vxStats
To: Carl Lionberger <[email protected]>
Cc: [email protected], [email protected], Andrew Johnson <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Fri, 4 Oct 2002 10:07:29 +0200
I see ...
My guess is that your
ResourceMonitor/Reboot/ASGcontrol/TimeOfDay/BootTime/IOCStatistics/BootDirectory
module has definitely left the realm of soft device support. It has
become a full-fledged application containing multiple record types,
device supports, additional code, panels, databases and more. (This is
what I see in the LBL version and you said it's been further developed
since then.)
In that case I would suggest taking it out of the Soft Support List and
point to the original unbundled vxStats device support instead, which is
kept and maintained at the APS.
Should we open up a third category for "Portable Applications" which
this might go into? Or is it a member of class "facility" within the
"Soft Support List"?
Anyway, if it stays somewhere in the EPICS web, I would really, really
suggest renaming it to something different than vxStats, since this is
the name of the unbundled device support that people will be looking for
in the first place (since it used to be part of base).
Cheers, Ralph
>>>>> "Carl" == Carl Lionberger <[email protected]> writes:
  > And there is a version we are using at SNS that has diverged and continues
  > to do so; it is derived from the older lbl version.  The latest proposed
  > change I've heard about is to display the boot directory.  We have a time
  > readout and a record of the boot time as well.
  > The LBL version on the ftp site is pretty old by now and probably shouldn't
  > be pointed to anyway, although I don't really have much opinion on which
  > should be pointed to instead.
  >     Carl
Re: Caveat: vxStats Carl Lionberger
Caveat: vxStats Ralph . Lange
Prev: Re: Caveat: vxStats Carl Lionberger
Next: Re: Caveat: vxStats Carl Lionberger
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
