1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problem with EPICS RULES.Host (R3.13.7 but also before)
To: Pete R Jemian <[email protected]>
Date: Wed, 16 Oct 2002 17:13:30 -0500
DBDINSTALL files should be specified without a directory.
The rules in RULES.Host will install DBDINSTALL files from
either the src directory or the O.* directory.
The clean rule in RULES.Host is the problem. It does a remove
of $(DBDINSTALL). I will change "$(DBDINSTALL)" to "*.dbd"
in the clean rule so it removes only created dbd files in the
O.* directory. This change will appear in the next R3.13 release.
Janet
Pete R Jemian wrote:
Who can fix this?
Discovered a problem with the R3.13.7/base/config/RULES.Host
while building in the source tree of a top level directory.
In the $(TOP)/topApp/src/Makefile.Host file, there is a directive
DBDINSTALL += ../topShare.dbd
When I issue a
    cd $(TOP)/topApp/src
    gnumake rebuild
in that $(TOP)/topApp/src/ directory, the process fails
with a complaint that it cannot rebuild  topShare.dbd.
Inspection of the directory shows that the process
has deleted the file!
After reinstalling that file, I compare the result with
    cd $(TOP)
    gnumake rebuild
This works properly.
This is not good. This has happened for some time
now (maybe since at least 3.13.0).  I believe this to
be a general problem which is not specific to the
mca5_1/mcaApp/src directory being rebuilt at the time.
Pete Jemian
UNICAT
[email protected]
problem with EPICS RULES.Host (R3.13.7 but also before) Pete R Jemian
Prev: problem with EPICS RULES.Host (R3.13.7 but also before) Pete R Jemian
Next: Another Notice for the EPICS collaboration meeting Bob Dalesio
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
