>>>>> "Ned" == Ned Arnold <[email protected]> writes:
Ned> The short answers are ...
>> From: "Redman, Russell O." <[email protected]>
>> My big questions are thus
>> 1) Under what circumstances does pushing a value over a CA link cause the
>> target record to process?
Ned> .... if the destination field is defined as "PP" (with the statement
Ned> "pp(TRUE)" in the *.dbd file and so documented under the PP column in
Ned> the record reference manual) and the record scan field is set to
Ned> "Passive". If these two conditions are true, the record will process
Ned> when ANY channel access client (including a sequence programs, CA
Ned> links, etc) writes to that field.
So it is a record type property? There is no way to vary it per record
instance?
Mahalo,
Jim
Implication -> more special record types :-(
- Re: Your Message Sent on Thu, 31 Oct 2002 12:25:33 -0800 Andrew Johnson
- Re: Your Message Sent on Thu, 31 Oct 2002 12:25:33 -0800 Ned Arnold
<2002>
2025
2026
<2002>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
