Hi Vijayram,
Krishna wrote:
Andy, I have compiled the build, after compilation it
created bin, config and configure directories as
output but it failed to build the src directory, this
is the output I got, Could you suggest me as to what
could have gone wrong for it build the src files of
the build,
Ok, your Linux system doesn't have the /usr/lib/libreadline library
installed, which I guess we assumed that all Linuxes would have. The
simplest answer would be to tell you to install that using the relevent
RPM (or whatever package system your linux version uses), but there are
several versions of the readline library on our systems here and I'm not
sure which version we use/need. I suspect it's the .so version though if
you want to try installing a suitable package containing that.
For other OSs where libreadline isn't available there is an emulator
included in the EPICS code, but to switch to that you'd need to modify the
configuration and possibly some of the Makefiles, and I'm not the best
person to handle that kind of issue, so I've copied this message to Janet
Anderson, who is the expert on the build system.
Janet,
what's the simplest way to resolve this? Will ld be looking for
libreadline.a or one of the .so versions (which are in different Linux
RPMs on Red Hat at least). How easy would it be to switch to using
epicsReadline instead on Linux? We need to resolve this problem and
either put libreadline as a requirement on Linux or make it easy to
include or exclude within the build system.
- Andrew
--- Andrew Johnson <[email protected]> wrote:
Hi Vijayram,
Krishna wrote:
If my host itself is the target for building the
software, could you guide me as to if I should do
changes to specify
cross-compile-target-architecture.
My host is linux-x86 and I would like to make
itself
as my target architecture.
The R3.14 build system will compile everything for
the host machine
automatically. You only need to set
CROSS_COMPILER_TARGET_ARCHS if you
want it to cross-compile for a different target
(usually RTEMS or vxWorks)
- leave it blank or commented out for just native
binaries.
- Andrew
"Life is what happens while you're busy making other
plans." - John Lennon
__________________________________________________
Do you Yahoo!?
U2 on LAUNCH - Exclusive greatest hits videos
http://launch.yahoo.com/u2
make -C src buildInstall
make[1]: Entering directory `/home/gopu/epics/base/src'
make -C toolsComm buildInstall
make[2]: Entering directory `/home/gopu/epics/base/src/toolsComm'
make -C antelope buildInstall
make[3]: Entering directory `/home/gopu/epics/base/src/toolsComm/antelope'
perl ../../../configure/tools/makeMakefile.pl O.linux-x86 ../../../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 buildInstall
make[4]: Entering directory `/home/gopu/epics/base/src/toolsComm/antelope/O.linux-x86'
make[4]: Leaving directory `/home/gopu/epics/base/src/toolsComm/antelope/O.linux-x86'
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -pedantic -O3 -w -D_NO_PROTO -mcpu=pentium -fPIC -I. -I.. -I/home/gopu/epics/epics_install2/include/os/Linux -I/home/gopu/epics/epics_install2/include ../closure.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -pedantic -O3 -w -D_NO_PROTO -mcpu=pentium -fPIC -I. -I.. -I/home/gopu/epics/epics_install2/include/os/Linux -I/home/gopu/epics/epics_install2/include ../error.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -pedantic -O3 -w -D_NO_PROTO -mcpu=pentium -fPIC -I. -I.. -I/home/gopu/epics/epics_install2/include/os/Linux -I/home/gopu/epics/epics_install2/include ../lalr.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -pedantic -O3 -w -D_NO_PROTO -mcpu=pentium -fPIC -I. -I.. -I/home/gopu/epics/epics_install2/include/os/Linux -I/home/gopu/epics/epics_install2/include ../lr0.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -pedantic -O3 -w -D_NO_PROTO -mcpu=pentium -fPIC -I. -I.. -I/home/gopu/epics/epics_install2/include/os/Linux -I/home/gopu/epics/epics_install2/include ../main.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -pedantic -O3 -w -D_NO_PROTO -mcpu=pentium -fPIC -I. -I.. -I/home/gopu/epics/epics_install2/include/os/Linux -I/home/gopu/epics/epics_install2/include ../mkpar.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -pedantic -O3 -w -D_NO_PROTO -mcpu=pentium -fPIC -I. -I.. -I/home/gopu/epics/epics_install2/include/os/Linux -I/home/gopu/epics/epics_install2/include ../output.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -pedantic -O3 -w -D_NO_PROTO -mcpu=pentium -fPIC -I. -I.. -I/home/gopu/epics/epics_install2/include/os/Linux -I/home/gopu/epics/epics_install2/include ../reader.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -pedantic -O3 -w -D_NO_PROTO -mcpu=pentium -fPIC -I. -I.. -I/home/gopu/epics/epics_install2/include/os/Linux -I/home/gopu/epics/epics_install2/include ../skeleton.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -pedantic -O3 -w -D_NO_PROTO -mcpu=pentium -fPIC -I. -I.. -I/home/gopu/epics/epics_install2/include/os/Linux -I/home/gopu/epics/epics_install2/include ../symtab.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -pedantic -O3 -w -D_NO_PROTO -mcpu=pentium -fPIC -I. -I.. -I/home/gopu/epics/epics_install2/include/os/Linux -I/home/gopu/epics/epics_install2/include ../verbose.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -pedantic -O3 -w -D_NO_PROTO -mcpu=pentium -fPIC -I. -I.. -I/home/gopu/epics/epics_install2/include/os/Linux -I/home/gopu/epics/epics_install2/include ../warshall.c
/usr/bin/g++ -o antelope closure.o error.o lalr.o lr0.o main.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o warshall.o -lpthread -lreadline -lcurses -lrt
/usr/bin/ld: cannot find -lreadline
collect2: ld returned 1 exit status
make[4]: *** [antelope] Error 1
make[3]: *** [buildInstall.linux-x86] Error 2
make[3]: Leaving directory `/home/gopu/epics/base/src/toolsComm/antelope'
make[2]: *** [antelope.buildInstall] Error 2
make[2]: Leaving directory `/home/gopu/epics/base/src/toolsComm'
make[1]: *** [toolsComm.buildInstall] Error 2
make[1]: Leaving directory `/home/gopu/epics/base/src'
make: *** [src.buildInstall] Error 2
"Life is what happens while you're busy making other plans." - John Lennon
Re: EPICS R3.14 problem Ralph Lange
Re: EPICS R3.14 problem Eric Norum
<2002>
2025
2026
Cexp 1.0_beta is released - yet another runtime loader for RTEMS Till Straumann
<2002>
2025
2026
