See if the file exists in the directory
/usr/local/epics/extensions/lib/solaris
Remember to change solaris to your OS when you take a look and also epics
may be in a different parent directory on your system..
The following is a listing of all the files in my extensions/lib/solaris
directory:
libANLwidgets.a libSDDS1c.a libezcaScan.so libnamelist.a
libChanArchIO.a libTools.a libfftpack.a libpprsyd.a
libEzcaScan.a libarAccess.a libgd.a librpnlib.a
libEzcaScan.so libdev.a libmatlib.a libsca.a
libJpt.a libezca.a libmdbcommon.a libsddsIDL.a
libLca.a libezca.so libmdblib.a libsddsIDL.so
libLca.so libezcaIDL.a libmdbmth.a libtclCa8.a
libPrintUtils.a libezcaIDL.so libmdbplt.a libtclCa8.so
libSDDS1.a libezcaScan.a libmeschach.a
You may have the file libSDDS1c.so which is a dynamically linking library
whereas the *.a files are static libraries. You should change the settings
in the make file to build either dynamically or statically. Some times you
may have noticed a loading error when you execute a program involving
"ld.so.1" this means the dynamic loader cannot find the library xxxx.so in
its search path.
-----Original Message-----
Sent: Wednesday, November 13, 2002 12:05 PM
To: [email protected]
Subject: SDDS problem
I am trying to install burt tool, which required installation of
SDDS package.
When I tried to install SDDS package it gave this error,
libSDDS1c.a: No such file or directory.
for which I tried installing SDDSlib package in SDDS directory,
still I am getting the same error,
This is the output I am getting,
......./Makefile.Host:229: warning: overriding commands for target
`libSDDS1.so'
/usr/local/epics/base/config/RULES.Host:715: warning: ignoring old
commands for target `libSDDS1.so'
rm -f libSDDS1c.a
ar -rc crv libSDDS1c.a SDDS_binary.o SDDS_data.o SDDS_output.o
SDDS_process.o SDDS_utils.o SDDS_write.o SDDS_input.o
SDDS_dataprep.o SDDS_ascii.o SDDS_extract.o SDDS_copy.o SDDS_rpn.o
SDDS_mplsupport.o SDDS_info.o SDDS_transfer.o
ar: libSDDS1c.a: No such file or directory
make[1]: *** [libSDDS1c.a] Error 1
make[1]: Leaving directory
`/usr/local/epics/extensions/src/SDDS/SDDSlib/O.linux-x86'
make: *** [install.linux-x86] Error 2
Could anyone help me getaround this problem,
Thankx in advance for any help,
Vijayram.
SDDS problem vijayram v g
RE: SDDS problem Tim Graber
<2002>
2025
2026
<2002>
2025
2026
