1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: SDDS problem
To: Tim Graber <[email protected]>, [email protected]
Date: Wed, 13 Nov 2002 16:15:52 -0600
Vilayram is compiling on Linux. In the Makefile.Host it checks to see if OS_CLASS == Linux. If so it redefines AR=ar to remove the -rc options. Somehow the OS_CLASS is not getting set correctly.
--Bob Soliday
Tim Graber wrote:
I tried running the "ar" command manually in my O.solaris directory after
deleting the libraries.  When I ran the command you are running "ar -rc crv"
I got the same result as you. However the correct command "ar crv"  Creates
the library on my system as shown below. Something looks like it is not
configured correctly in the Makefile or possibly something in the config
directory.  My Makefile.Host has the following line:
Makefile.Host:  $(AR) c$(ARFLAGS) libSDDS1c.a $(LIB1cOBJS)
where AR =ar etc...
Does anyone else have any ideas?
ar -rc crv libSDDS1c.a *.o
ar: cannot open libSDDS1c.a No such file or directory
ar crv libSDDS1c.a *.o
a - SDDS_ascii.o a - SDDS_binary.o a - SDDS_copy.o a - SDDS_data.o a - SDDS_dataprep.o a - SDDS_extract.o a - SDDS_info.o a - SDDS_input.o a - SDDS_mplsupport.o a - SDDS_output.o a - SDDS_process.o a - SDDS_rpn.o a - SDDS_rpndummy.o a - SDDS_transfer.o a - SDDS_utils.o a - SDDS_write.o ar: writing libSDDS1c.a
-----Original Message-----
Sent: Wednesday, November 13, 2002 12:11 PM
To: [email protected]
Subject: SDDS problem
I am trying to install burt tool, which required installation of SDDS package.
When I tried to install SDDS package it gave this error,
libSDDS1c.a: No such file or directory.
for which I tried installing SDDSlib package in SDDS directory, still I am getting the same error,
This is the output I am getting,
......./Makefile.Host:229: warning: overriding commands for target `libSDDS1.so'
/usr/local/epics/base/config/RULES.Host:715: warning: ignoring old commands for target `libSDDS1.so'
rm -f libSDDS1c.a
ar -rc crv libSDDS1c.a SDDS_binary.o SDDS_data.o SDDS_output.o SDDS_process.o SDDS_utils.o SDDS_write.o SDDS_input.o SDDS_dataprep.o SDDS_ascii.o SDDS_extract.o SDDS_copy.o SDDS_rpn.o SDDS_mplsupport.o SDDS_info.o SDDS_transfer.o
ar: libSDDS1c.a: No such file or directory
make[1]: *** [libSDDS1c.a] Error 1
make[1]: Leaving directory `/usr/local/epics/extensions/src/SDDS/SDDSlib/O.linux-x86'
make: *** [install.linux-x86] Error 2
Could anyone help me getaround this problem,
Thankx in advance for any help,
Vijayram.
RE: SDDS problem Tim Graber
Prev: RE: SDDS problem Tim Graber
Next: CA protocol documentation. Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
