1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA protocol documentation.
To: "'Christopher A. Larrieu'" <[email protected]>
Cc: "'Tim Mooney'" <[email protected]>, "'EPICS-tech-talk'" <[email protected]>
Date: Thu, 14 Nov 2002 16:11:10 -0700
>   No, there's a lot to be said for Java's cross-platform
> capabilities.
> Currently, if I want to access CA from java, I need to build
> the CA library for every platform on which my Java app will run.
I seems that on a fundamental level this question comes down to whether
it is easier to completely reproduce the CA client libraries in JAVA, or
whether it is easier to build and distribute a set of binaries for the
set of architectures that we use. The effort to support the latter might
be distributed over several sites if there is some mechanism by which a
site using a new architecture can build EPICS and then upload the result
into a central web based repository for use by other sites that may have
that same architecture. An EPICS RPM for Linux might also help with this
chore.
Jeff
Re: CA protocol documentation. Tim Mooney
RE: CA protocol documentation. Christopher A. Larrieu
Prev: RE: CA protocol documentation. Christopher A. Larrieu
Next: Re: RE: CA protocol documentation. tieman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: CA protocol documentation. Tim Mooney
