1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: building R3.14 problem for RTEMS
To: "M.C.Shao" <[email protected]>
Cc: Andrew Johnson <[email protected]>, Tech-talk <[email protected]>
Date: Mon, 18 Nov 2002 02:29:30 -0800
M.C.Shao wrote:
hi, I am building R3.14 for RTEMS 4.5.0. During make process, it was said that "/opt/rtems/bin//opt/rtems/bin/i386-rtems/gcc: command not found".Obviously,the path is wrong,it should be "/opt/rtems/bin/i386-rtems/gcc".I have checked all the configure files, but didn't figure out where to address this problem.
This is configured in epics/base/configure/os/CONFIG.Common.RTEMS
where RTEMS_BASE is set.
-- Till
Please give me some suggestions.It seems that you're using old versions of RTEMS. but the directory architecture of new RTEMS versions is different from old ones.
M.C.Shao
"yesterday is a history,tomorrow is a mystery,today is a gift.that's why we call it present"--by someone
Re: building R3.14 problem for RTEMS M.C.Shao
Extensions problem Krishna Arya
Re: Extensions problem Andrew Johnson
base building problem M.C.Shao
Re: base building problem Andrew Johnson
Prev: alarms and autodialers Peregrine M. McGehee
Next: Re: building R3.14 problem for RTEMS M.C.Shao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: building R3.14 problem for RTEMS M.C.Shao
