1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VDCT groups
To: EPICS tech-talk <[email protected]>
Date: Fri, 29 Nov 2002 17:29:18 +0100
Grouping and hierarchies would be one of the most important reasons to use VDCT.
We even need the transparent forwarding of macro substitutions - which is disabled at the moment.
We should collect the requirements for the next release...
Matthias
John Maclean wrote:
> We are drawing up requirements for future versions of VDCT.
> Based on discussions with a number of people it appears the the grouping
> facility is not used but is often a source of confusion.
> So the question is, should we remove grouping from VDCT? If we don't
> remove it then it will certainly be turned off by default.
> Note that groups are different from the hierarchy scheme that is now
> being implemented. See the user manual at
> http://www.cosylab.com/visualdct/builds/VisualDCT/2.3.1238/doc/MAN-VisualDCT_Users_Manual.html
> if you need more information on groups or hierarchies.
> If no one objects we'll remove grouping.
> John Maclean.
begin:vcard
n:Clausen;Matthias
tel;pager:FAX-personal : 49-40-8994-3256
tel;cell:-49-1759346253
tel;fax:-49-40-8998-4388
tel;home:+49-4105-669090
tel;work:-49-40-8998-3256
x-mozilla-html:TRUE
url:http://www.desy.de/~claus
org:DESY;MKS-2 / Kältekontrollen
adr:;;Notkestrasse 85;Hamburg;;22607;Germany
version:2.1
email;internet:[email protected]
title:Wissensch. Mitarbeiter/ Information System Manager
fn:Matthias Clausen
end:vcard
Re: VDCT groups Luedeke Andreas
VDCT groups John Maclean
Prev: Re: VDCT groups Luedeke Andreas
Next: device support routines for RS232 Lifang Zheng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: VDCT groups Luedeke Andreas
