Subject: |
Re: Building 3.14 on solaris Was: Building 3.13Extensions with 3.14 base Problem. |
Peter Kurpis <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 5 Dec 2002 12:25:23 -1000 (HST) |
> Date: Thu, 05 Dec 2002 14:42:14 -0600
> From: Andrew Johnson <[email protected]>
> The easy answer is to set your LD_LIBRARY_PATH environment variable to a
[snip]
> Personally I think that on Linux at least we should be embedding the paths
> to the shared libraries into those binaries that use them. I have this
> working, and will see if I can persuade Janet to accept it for R3.14.1
A little off the original topic, but for what it's worth, below is how to
avoid LD_LIBRARY_PATH in a solaris build of 3.14 (beta 2), in a fairly
generic environment. (Note that GNU recommends using Solaris as and ld
with gcc/g++.)
First, make configuration file mods as shown below. Note I am not doing
the vxworks builds for now.
$ cd /usr/local/epics/r3.14.0beta2/base/configure
$ diff CONFIG_SITE.original CONFIG_SITE
60,61c60
< #CROSS_COMPILER_TARGET_ARCHS=
< CROSS_COMPILER_TARGET_ARCHS=vxWorks-68040 vxWorks-ppc604
95c94
< SHARED_LIBRARIES=NO
> SHARED_LIBRARIES=YES
$ cd /usr/local/epics/r3.14.0beta2/base/configure/os
$ cat CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu
GNU_DIR = /usr/local
LD = /usr/ccs/bin/ld -r
DEPLIB_DIRS += /usr/local/lib /usr/local/epics/r3.14.0beta2/base/lib/solaris-sparc-gnu
SHRLIB_LDFLAGS_YES = -Wl,-G -Wl,-dy
SYS_SHRLIB_LIBS = posix4 pthread
Then, the procedure, simply:
setenv EPICS_HOST_ARCH solaris-sparc-gnu
gmake >& make.log
Note that the SYS_SHRLIB_LIBS redefinition was, if I recall correctly, to
remove the Crun from its definition in CONFIG.Common.solaris-sparc .
The libCrun, however, might be needed to allow R3.13 build extentions to
load R3.14 shared libs, per a comment in that file. Its inclusion, however,
broke my build on Solaris 8. Perhaps the build has changed since then, as
this was in flux (e.g. changed from beta1).
Hope this helps.
Fwd: Xwindow print from Linux Pete R Jemian
MEDM - alarm status not propagated for vis.calc Brian McAllister
<2002>
2025
2026
<2002>
2025
2026
