Jim Thomas wrote:
Aloha,
Consider a select record with SELM == "Specified" (SELECTED in the code).
The select record initializes non-constant inputs to 1e+30 . Then on
processing, only the selected input is fetched (contrary to the
documentation). That leaves non-selected links as 1e+30 . Then if one
tries a dbpr on that record, on a SPARC at least, one gets a floating point
exception in dbStatic/dbStaticRun.c:realToString at intval=value; . Since
that may happen on other architectures too, it seems like a check against
MAXINT is warranted around the easy integer case?
Jim
I could not reproduce this but I do agree that it is a good idea to check for
int_max. I will make the changes for release 3.14.1
Marty
- select record versus dbpr() versus SPARC (at least) Jim Thomas
Re: select record versus dbpr() versus SPARC (at least) Benjamin Franksen
<2002>
2025
2026
<2002>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
