Hello,
I'm testing the Agilent E5810A LAN box on an 3.14/RTEMS and 3.14/vxWorks IOC.
The E5810A will not reboot when requested by drvHpGpibConfig (pre-iocInit link configuration). Unlike the 2050A/B, the reboot is password-protected on the E5810A. Without the reboot, I must manually reboot the LAN box before rebooting my IOC. If I don't, the third time my IOC reboots, and forever after, I get this:
drvHpGpibConfig(2,"ip_address_deleted",0,3000,"gpib0")
drvHpE2050AGpib (release 1.0) initialized successfully
drvGpib (release 3.0) initialized successfully
drvGpibLinkTask(gpib00002): started
RTEMS:
hpGenLink(0x1c59178): can't connect to gateway: No more processes
vxWorks:
hpGenLink(0xf8c8b0): can't connect to gateway: S_errno_ETIMEDOUT
drvGpibLinkStart(0x1c59178): linkTask init failure / timeout
Has anyone (Noboru?) solved this problem yet?
Thanks for any response,
Stephanie Allison
SSRL/Spear Controls
>From Sep 2002 archives:
>We have tested E5810A with EPICS E2050B support and confirmed it works with
>it. You may need to change a startup script or setting of E5810A, though.
>The default "GPIB SICL Interface name" on
>HP2050A is "hpib" whereas it on HP5810A is "gpib0".
>After changing "hpib" in drvHpGpibConfig command in the startup script
>to "gpib0". EPICS software can establish the link and can control GP-IB
>devices under the LAN-GPIB box, HP5810A. We are going to test the HP
>5810A in more detail.
>Regards,
>Noboru Yamamoto
>EPICS group/KEKB control Group
>KEK, JAPAN
a question about edm 黄松
_excStub & _excIntStub Owens, PH (Peter)
<2003>
2025
2026
<2003>
2025
2026
