1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Setup/Installation
To: "Mike A. Larson" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 15 Jan 2003 09:48:08 +0100
Hi Mike,
the main problem is that EPICS is a large full toolbox of things and
every single installation is using different tools and different parts
to achieve different things. So - other than with a standard pc or your
CD player - there is no way to create a simple one page instruction
poster. Also in most cases building a control system is slightly more
complicated than plugging your computer into the wall.
It's like with any toolbox: you will have to get to know and understand
the tools to get something going.
On the other hand there is a common minimal set of tools that probably
all installations are using. The chapters 2 and 3 of the Application
Developer's Guide give a reasonable introduction. An example application
that is part of EPICS base that will get you started with a small
running EPICS system almost immediately. There is a README file on the
main doc web page that contains necessary information to compile and run
EPICS base and the example. Read it.
Last not least: EPICS is a collaboration. As soon as you are able to put
all the necessary information together on a nice poster, we will be more
than happy to integrate it into the EPICS release. Everyone will love
you for doing that. (I can't promise kisses, though.)
Cheers,
Ralph Lange
>>>>> "Mike" == Mike A Larson <[email protected]> writes:
  > I am in search of some basic common denominator instructions for setting up
  > an EPICS system.  I am currently running Red Hat 7.3.  Most of the
  > instruction and tutorial do not go into good detail.  I am searching for
  > something close to that Dell poster that you get telling you how to plug
  > your computer into the wall.  Most of the installation instructions I have
  > found thus far consist of comments like "Now go for the gusto and compile"
  > I guess I am looking for everything up to and including this compile step.
  > Thanks and pardon my ignorance,
  > Michael Larson
EPICS Setup/Installation Mike A. Larson
Prev: OMS 58 and auxiliary outputs Rok Sabjan
Next: Re: Where is caput? Andy Foster
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS Setup/Installation Mike A. Larson
Next: [no subject] psichta
