1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CAN bus and PPC processors
To: "'[email protected]'" <[email protected]>
Date: Wed, 15 Jan 2003 13:24:43 -0600
One of the detector groups wants to use a Weiner power supply, model
Floating Power Supply PL500-F8, connected via CAN bus.  CAN bus is new
for us.  I looked on the EPICS web pages and noted that support was
available for the Tew TIP810 CAN bus interface using the IP slot on an
MVME162 or MVME172.  We use MVME2301 and MVME2304 boards.  Has anyone
attempted to use the TIP810 on a PPC board?  Any idea how hard this
might be to implement?  The alternative is to use an EPICS supported
IPAC card.  This would be the more expensive solution in terms of equipment.
Is the TIP810 the only EPICS support CAN bus interface?
Is a CAN bus controller that plugs directly into the VME bus a better
option?
The run from the CAN bus interface to the the power supply is about 100
feet.  Will this distance have an impact on operations?
Thanks
Geoff
Re: CAN bus and PPC processors John Maclean
Prev: Re: Has anyone ever written a tool... Benjamin Franksen
Next: Re: Where is caput? Ben-chin K. Cha
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Has anyone ever written a tool... Laznovsky, Michael
Next: Re: CAN bus and PPC processors John Maclean
