1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Fw: Re:RE: EPICS exmaple application problem
To: "Tech-talk" <[email protected]>
Date: Sat, 18 Jan 2003 16:21:05 +0800
> >From:"Jeff Hill" <[email protected]>
> >You might see this message in ordinary situations where the medm program
> >has lost communication with the IOC such as when the IOC powers down,
> >reboots, or its network cable is removed. This message might also occur
> >if there are software problems but it is difficult to speculate further
> >with this information.
> >What version of EPICS are you running?
> my EPICS version is R3.14.0beta2
> >Here are some steps you can follow to find the cause of the problem.
> >1) Use the ping command from the medm workstation to verify that there
> >is network connectivity to your IOC.
> yes, I could ping the ioc successfully.
> >2) Verify that there is not a CPU saturation problem on your RTEMS IOC
> >where 100% of the CPU is consumed.
> No, there is not such problem.
> >3) Did the medm screen only disconnect briefly and then reconnect on its
> >own? Temporary disconnect problems existed in one of the early beta
> >releases of R3.14.
> After turned to "execute" mode, the medm mornitor screen is white always.
> And the client exception message come out again and again, described in last
> mail.
> >4) If not, does another program such as caEventRate connect to the IOC
> >in this situation?
> when I use "caEventRate root:aiExample", it return nothing, and without error.
> On the ioc side, issue a "casr" command, I could see the connection like this:
> epics>casr
> Channel Access Server V4.11
> 166.111.32.251:32798(): User="", V4.0, Channel count=0, Priority=0
> when use medm, there is a record like above too.
> >Jeff
> best wishes,
> Shao Mingchao
> Tsinghua University,Beijing,China
Prev: Acromag IP Support Andy Foster
Next: baseR3.14.1 example application building problem M.C.Shao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS exmaple application problem M.C.Shao
Next: RE: PowerPC woes Woods, PD (Paul)
