Hello,
I am experimenting with EPICS base R3.14.1. running it on a
standard RedHat7.3 machine. I have written device support for a few NI DAQ
cards, which is going very well. In doing so, I noticed something
strange. The scan period seems to be consistently extended by an 100th
of a second, when using device support. I first noticed this when
I toggled a binary out at 10Hz to generate a square wave. I saw the
effect very clearly on the oscilloscope.
I then had a look at the time-stamps and saw the same thing. To
see if this was due to device support, I built an example with device
support that did nothing.
static long Inuit_bo();
static long write_bo();
struct {
long number;
DEVSUPFUN report;
DEVSUPFUN init;
DEVSUPFUN init_bo;
DEVSUPFUN get_ioint_info;
DEVSUPFUN write_bo;
}devBoDIO96={ 5,NULL,NULL,init_bo,NULL,write_bo,};
static long init_bo(pbo)
struct boRecord *pbo;
return(0);
static long write_bo(pbo)
return(0);
like so.
The scan rate was set to .1 and the same problem occurred.
Here is the ca-monitor with empty device support
DML:Bo0 02/05/03 16:06:27.070044
DML:Bo0 02/05/03 16:06:27.280062
DML:Bo0 02/05/03 16:06:27.490039
DML:Bo0 02/05/03 16:06:27.700034
DML:Bo0 02/05/03 16:06:27.910037
DML:Bo0 02/05/03 16:06:28.120074
DML:Bo0 02/05/03 16:06:28.330045
DML:Bo0 02/05/03 16:06:28.540051
DML:Bo0 02/05/03 16:06:28.750047
DML:Bo0 02/05/03 16:06:28.960049
Using soft records, there is no such problem.
Has anyone else noticed this?
any help would be greatly appreciated
best regards.
Dylan Maher-Loughnan
MIT-Bates Linear Accelerator Center
- Re: device support for R3.14.1 Linux IOC Andrew Johnson
EPICS base release 3.13.8 Marty Kraimer
<2003>
2025
2026
<2003>
2025
2026
