To include an Objective-C source file in an application just add it to the source list in the application Makefile: example_SRCS += exampleObjC.m To link the Foundation framework into an application add the following as well: example_LDFLAGS += -framework Foundation Here's a short example showing how the Foundation framework can be used to send AppleScript messages to other applications: /*
* exampleAppleScriptRecord.m
* Simple Objective-C/AppleScript subroutine record
* To use this record in an application:
* 1) Make the following changes to the application Makefile:
* - Add exampleAppleScriptRecord.m to the application SRCS.
* - Add -framework Foundation to the application LDFLAGS.
* 2) Add the following line to the application database description:
* function(exampleAppleScriptProcess)
* 3) Add a record to the application database:
* record(sub,"setVolume")
* field(SNAM,"exampleAppleScriptProcess")
#import <Foundation/Foundation.h>
#include <subRecord.h>
#include <alarm.h>
#include <errlog.h>
#include <recGbl.h>/*
* Shim between EPICS and NSAppleScript class.
long
exampleAppleScriptProcess(struct subRecord *psub)
NSAutoreleasePool *pool = [[NSAutoreleasePool alloc] init];
NSDictionary *err;
NSAppleScript *nsa;nsa = [[NSAppleScript alloc] initWithSource:[NSString stringWithFormat: @"tell application \"Finder\" to set volume %g\n", psub->A]]; if ([nsa executeAndReturnError:&err] == nil) { errlogPrintf("Failed to run AppleScript: %s\n", [[err objectForKey:NSAppleScriptErrorMessage] cString]); recGblSetSevr(psub, SOFT_ALARM, INVALID_ALARM); } [nsa release]; [pool release]; return 0; } -- Eric Norum [email protected] Advanced Photon Source Phone: (630) 252-2793 Argonne National Laboratory
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
