1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: HOST : WIN32 with IOC:Linux: is there environment variables in HOST?
To: LANGLOIS Florent <[email protected]>
Cc: Marty Kraimer <[email protected]>, "David H. Thompson" <[email protected]>, techtalk <[email protected]>
Date: Fri, 21 Feb 2003 07:06:09 -0500
Indeed, there are Env variables that need to be set on your WIN32
platform.  The two main env vaiables for channel access clients for
EPICS 3.14:
Search the local subnet for the PV of your choice
Must be set to either YES or NO
EPICS_CA_AUTO_ADDR_LIST=<YES/NO>
Search specific CA servers in a certain order
EPICS_CA_ADDR_LIST=<A list of CA server IP addresses>
example, given that my linux-x86 IOC's IP number is 172.20.72.67, then
EPICS_CA_ADDR_LIST=172.20.72.67
When using large arrays in 3.14 max array size in bytes
EPICS_CA_MAX_ARRAY_BYTES=<max array size in bytes>
By the way the same env variables must be set on any host including
LINUX.
For more info about CA env variables see:
http://www.aps.anl.gov/epics/modules/base/R3-14/1-docs/CAref.html
Ernest L. Williams JR.
SNS Control Systems Group
ORNL
On Fri, 2003-02-21 at 06:04, LANGLOIS Florent wrote:
> hi everyone,
> i have a WIN32 channel access client and an IOC running on a linux x86 .
> i want to read/write PVs/records from my client to the ioc
> but it doesn't work
> however, when i use a channel access client on the ioc linux platform, it works!
> so is there an env variable or something so that i can read the records from the network in my WIN32 platorm?
> im not sur if i have been clear, but i hope you could answer me!
> thank you
> Florent Langlois
> Division Informatique
> Synchrotron SOLEIL
> L'Orme des Merisiers
> St-Aubin - BP 48
> 91192 GIF-sur-YVETTE
> TÃl : 01.69.35.93.31
> [email protected]
> www.synchrotron-soleil.fr
Re: HOST:WIN32 with IOC:Linux: is there environment variables in HOST? Ralph Lange
HOST : WIN32 with IOC:Linux: is there environment variables in HOST? LANGLOIS Florent
Prev: HOST : WIN32 with IOC:Linux: is there environment variables in HOST? LANGLOIS Florent
Next: Re: HOST:WIN32 with IOC:Linux: is there environment variables in HOST? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
