Thank you very much, it work with the env variable:
set EPICS_CA_ADDR_LIST=<adresse serveur linux>
florent
-----Message d'origine-----
De : Ralph Lange [mailto:[email protected]]
Envoyé : vendredi 21 février 2003 13:37
À : LANGLOIS Florent
Cc : Ernest L. Williams Jr.; EPICS Tech-Talk
Objet : Re: HOST:WIN32 with IOC:Linux: is there environment variables in
HOST?
> Indeed, there are Env variables that need to be set on your WIN32
> platform. The two main env vaiables for channel access clients for
> EPICS 3.14:
> By the way the same env variables must be set on any host including
> LINUX.
> For more info about CA env variables see:
> http://www.aps.anl.gov/epics/modules/base/R3-14/1-docs/CAref.html
Looking in the docs is definitely worth giving a try, but generally
all these environment variables have reasonable default values, so you
only _have_ to set them if your system is configured in a non-standard
way.
Other things to look for include:
- Check the network connection of your windows box: Is the IP number in
the right network? Does the network mask match? Can you ping the IOC
system from the windows command line?
- If your windows box and the IOC are not in the same IP subnet: Read
the appropriate chapter of the Channel Accesss doc. In this case you
_will_ have to set variables on the client system to make things work.
- Check the environment on your working linux client system: if any
variables related to CA are set, try setting them accordingly on the
windows box.
- Check the environment of your linux IOC system: are any CA-related
variables set which change the behaviour of the IOC? You will have to
use the matching settings on the client system.
- Check if your linux IOC has Access Security enabled. If so, the
Access Security file might have to be changed to allow access from
your windows box.
All Channel Access environment variables are described in the doc that
Ernest pointed you to.
Access Security is documented in the Application Developer's Guide.
First of all: Good luck!
Ralph
Re: HOST:WIN32 with IOC:Linux: is there environment variables in HOST? Ralph Lange
Commercial RTOS to replace vxWorks john sinclair
<2003>
2025
2026
<2003>
2025
2026
