1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How can i find a reference manual on EZCA (other than EZCA Primer)
To: LANGLOIS Florent <[email protected]>
Cc: "Tech-Talk (E-mail)" <[email protected]>
Date: Mon, 03 Mar 2003 07:38:13 -0600
LANGLOIS Florent wrote:
Do you know where i can find some help : reference and examples on EZCA clients.
Have you seen
http://www.aps.anl.gov/epics/extensions/index.php
In particular the section on  "CA Interfaces to other tools and languages"
provides some links to ezca documentation.
can i use callback function with it?
Since it provides ezcaPvToChid the answer is yes.But then you are back to standard CA API calls. The main reason ezca was developed was because some users said that they did not want to program via callbacks. Thus if an application wants callbacks it may be better to just use the CA API.
Marty Kraimer
thanks --------------------------------- Florent Langlois [email protected]
How can i find a reference manual on EZCA (other than EZCA Primer) LANGLOIS Florent
Prev: How can i find a reference manual on EZCA (other than EZCA Primer) LANGLOIS Florent
Next: Job Opening Ned D. Arnold
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
