1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Long expressions using MAX and MIN in CALC fields
To: Dirk Zimoch <[email protected]>
Cc: TECHTALK <[email protected]>
Date: Wed, 19 Mar 2003 05:51:01 -0600
Dirk, re...,
> Tim Mooney wrote:
> > Russell,
> > I have new versions of postfix and calcPerform, which implement the
> > <? and >? operators, and which allow two or more (up to 20) arguments
> > to min() and max() functions.  I've tested only under R3.13.5 on an
> > MV162.  Here's the tar file:
> > http://www.aps.anl.gov/xfd/SoftDist/swBCDA/postfix_R3.13.5.tar.gz
> There seems to be a problem with the calcCheck() function.
> When I try to use the ? operator without : (that is allowed), I get this
> error:
> Illegal field value PV: ZIMOCH:calc  calc: special: Illegal CALC field
> I tried "A>B?C"
> Using ?: works fine
That never occurred to me, though you're right, ? without : is documented in
the record reference manual.  Paraphrasing, it says the result of "a?b" is b
if a is true, and "unchanged" if a is not true.  This is a bit cryptic, because
in fact, old calcPerform() returned an error if it encountered ? without :, and
the calc record left its result alone
Tim Mooney ([email protected]; 630-252-5417)
Advanced Photon Source
APS Operations Division
Beamline Controls & Data Acquisition Group
Long expressions using MAX and MIN in CALC fields Redman, Russell O.
Re: Long expressions using MAX and MIN in CALC fields Tim Mooney
Re: Long expressions using MAX and MIN in CALC fields Dirk Zimoch
Prev: Re: Long expressions using MAX and MIN in CALC fields Dirk Zimoch
Next: Re: the length of channel name Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Long expressions using MAX and MIN in CALC fields Redman, Russell O.
