1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: multithread client
To: "'l7a'" <[email protected]>, <[email protected]>
Date: Mon, 5 May 2003 13:48:36 -0600
Hello Andrei,
I was cleaning out my mail today and I found your question. My
answer is inserted below.
Best regards,
Jeff
> A small question about client Auxiliary Threads. The way in
> Auxiliary
> Thread is
> 1. Start thread.
> 2. Check current CA context
> 	struct ca_client_context * ca_current_context ();
> 3. if struct ca_client_context == NULL
> 		ca_context_create(ca_enable_preemptive_callback)
> //init CA
>    else
> 		int ca_attach_context (struct ca_client_context
> *CONTEXT);//join
> 4. WORK
> *****5. Does deattach_context need? (Of course, I can not call
> destroy.)
There is no need to provide a call which detaches from the CA
context because no resources were reserved by
ca_attach_context(). There is a call to destroy a CA context
after all of your threads are done with it.
> 6. Stop thread.
> Best wishes,
> Andrei.
> Hello Andrei,
> > Can somebody show example with multithread client?
> To set up a preemptive callback enabled CA client context you
> will need code like this.
>     SEVCHK(ca_context_create(ca_enable_preemptive_callback),
>         "application pdq calling ca_context_create");
> To set up a traditional single threaded client you will need
> code
> like this.
>     SEVCHK(ca_context_create(ca_disable_preemptive_callback),
> I added these examples to the manual for the next release.
> > But I could not image how I can say CA library to use new
> > (auxiliary) thread for its callback fuctions.
> The CA client library spawns off its own private auxiliary
> threads which call the user callbacks and take care of other
> background activities.
> > Is it possible I need to call
> > ca_add_event() or ca_pend_event() in new thread?
> The ca_add_event() function install a subscription for state
> change call backs. It can be called from any thread in the CA
> client context.
> The ca_pend_event() function need not be called if you have
> enabled preemptive callback. Otherwise, it should be called
> from
> the thread that created the CA client context.
> There is more information on ca client library contexts in the
> latest CA client reference manual. Here is an excerpt.
> Thread Safety and Preemptive Callback to User Code
> Starting with EPICS R3.14 the CA client libraries are fully
> thread safe on all OS (in past releases the library was thread
> safe only on vxWorks). When the client library is initialized
> the
> programmer may specify if preemptive call back is enabled.
> Preemptive call back is disabled by default. If preemptive call
> back is enabled then the user's call back functions might be
> called by CA's auxiliary threads when the main initiating
> channel
> access thread is not inside of a function in the channel access
> client library. Otherwise, the user's call back functions will
> be
> called only when the main initiating channel access thread is
> executing inside of the CA client library. When the CA client
> library invokes a user's call back function it will always wait
> for the current callback to complete prior to executing another
> call back function.
> code
> like this (see ca_context_create and CA Client Contexts and
> Application Specific Auxiliary Threads) .
> SEVCHK ( ca_context_create(ca_disable_preemptive_callback ),
> "application pdq calling ca_context_create" );
> will need code like this (see ca_context_createand CA Client
> Contexts and Application Specific Auxiliary Threads) .
> SEVCHK ( ca_context_create(ca_enable_preemptive_callback ),
> CA Client Contexts and Application Specific Auxiliary Threads
> It may be necessary for several CA client side tools running in
> the same address space (process) to be independent of each
> other.
> For example, the database CA links and the sequencer are
> designed
> to not use the same CA client library threads, network
circuits,
> and data structures. Each thread that calls ca_context_create()
> for the first time either directly, or implicitly when calling
> a
> CA routine for the first time, creates a CA client library
> context. A CA client library context contains all of the
> threads,
> network circuits, and data structures required to connect and
> communicate with the channels that a CA client application has
> created. The priority of auxiliary threads spawned by the CA
> client library are at fixed offsets from the priority of the
> thread that called ca_context_create(). An application specific
> auxiliary thread can join a CA context by calling
> ca_attach_context() using the CA context identifier that was
> returned from ca_current_context() when it was called by the
> thread that called ca_context_create(). A CA client library
> context can be shut down and cleaned up, after destroying any
> channels or application specific threads that are attached to
> it,
> by calling ca_context_destroy().
> > 	I see epicsThread.h and epicsThread.cpp files. I believe
> > this is wrapper over os-depending threading. Am I right?
> Yes. See the application developer's guide.
> > Can I use this wrapper to hide Windows and Linux threads?
> > Can I see example too? Or have epicsThreadTestMain.cpp
> > and epicsThreadPrivateTest.cpp examples
> > enough information?
> That's a reasonable starting point. There are also many other
> codes in base 8-]
> Jeff
RE: multithread client l7a
Prev: Re: an error about building cdev server Brian Bevins
Next: Keithley 7001-Scanner...... Peter Mueller
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: multithread client l7a
Next: Re: Multiple Network quesion Adam DeGrush
