We at SLAC restore waveforms at IOC boot time. We've modified fdbrestore.c to use ca_array_put.
The source can be found here http://www.slac.stanford.edu/comp/unix/package/epics/extensions/ChannelWatcher/
Mike
-----Original Message-----
Sent: Friday, May 09, 2003 3:05 PM
To: EPICS Tech Talk
Subject: How to initialize waveform record
Greetings.
I have an application which wants to use a waveform record as
a lookup table. The initial values of the record would need to
be written once at IOC boot time. It would be suitable to use
something like 'dbpf' in the startup script, but I can't seem
to find a syntax that writes to array elements greater than
index 1. From a Solaris host, I can do
caput MY:ARRAY:RECORD 123 456 789
and all the values get written. Any comparable method using
the vxWorks shell? Or, better still, if I could supply a set
of default values at record initialization.
--- rod.
Rod Nussbaumer, Programmer/Technologist E-mail: [email protected]
TRIUMF --- University of British Columbia, Phone: (604)222-7449
Vancouver, BC, Canada. FAX: (604)222-7307
How to initialize waveform record Rod
Channel Archiver Display Tools Owens, PH (Peter)
<2003>
2025
2026
<2003>
2025
2026
