1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: converRelease.pl
To: [email protected]
Date: Mon, 26 May 2003 17:01:14 +0200
Hi all,
In 3.14.1, the script base/configure/tools/convertRelease.pl seems to expand configuration files (like configue/RELEASE), to create files to be included in make for a particular application and architecture. Unfortunately it does not take account of any environment variables, so if you set EPICS_BASE in your environment it will be ignorred and the value from your configuration files will be taken, or the build will fail if they are not defined.
This is causing us a problem, as we don't want to manualy edit these files every time we build epics in a different location (we are trying to speed up, and generalize our installation and build procedures).
Should this perl script be modified ? ( I can't do this as I can't even spell pearl!).
Thanks in advance
Steve Hunt
Re: converRelease.pl Ernest L. Williams Jr.
Re: convertRelease.pl Ralph Lange
Prev: Job Opening at APS Ned Arnold
Next: Re: converRelease.pl Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
