1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: channel access disconnects
To: "'[email protected]'" <[email protected]>
Date: Mon, 02 Jun 2003 11:00:21 -0500
I'm trying to understand the cause of sporadic but consistent CA write failures. The records in question are typically written every few hours and are spread across 12 IOCs. I have not been able to identify a pattern with the with failures in terms of one write failing consistently.
About a month ago I did discover that the client that writes to these records was not calling CA poll at least every 15 seconds as specified in the CA manual. For the last month the client calls CA poll once a second and the problems persist.
Any suggestions on where to look?
Thanks
Geoff
RE: channel access disconnects Jeff Hill
Prev: multicast storms, or how do WRS SPRs work Hoff, Lawrence
Next: Re: multicast storms, or how do WRS SPRs work Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: multicast storms, or how do WRS SPRs work Andrew Johnson
Next: RE: channel access disconnects Jeff Hill
