1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Datum (Bancomm) GPS glitches
Cc: "'Bill Cruise'" <[email protected]>, [email protected]
Date: Tue, 29 Jul 2003 10:18:41 -0500
Dirk Zimoch wrote:
if you don't have such a controller bit, you must do the following: * read the slow register * read the fast register * read the slow register again * repeat if slow register has changed
If my memory of the board is correct, the Bancomm time registers can be read in one particular order to latch the input time. This is documented in the user manual - I can't recall what the correct order is though. I would also suggest you try to get hold of a copy of the driver that Gemini and/or JCMT use, it should provide all of the facilities that you might need, links into the EPICS timestamp driver and doesn't suffer from the rollover problem.
- Andrew
There are 10 types of people in the world:
Those who understand binary, and those who don't.
RE: Datum (Bancomm) GPS glitches Jeff Hill
Re: Datum (Bancomm) GPS glitches Dirk Zimoch
Prev: Re: Datum (Bancomm) GPS glitches Dirk Zimoch
Next: Re: Datum (Bancomm) GPS glitches Bill Cruise
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
