> When looking at the channel access client information on IOCs running
> EPICS R3.13.4 we usually see the same name listed multiple times.
> Here is an example.
> Client Name="bartlett", Client Host="d0ol20.fnal.gov", V4.8, Channel
> Count=6
> TId=0X171E54, Protocol=TCP, Socket FD=11
> Secs since last send 1.63, Secs since last receive 1.63
> Unprocessed request bytes=0, Undelivered response bytes=0
> Client's DNS Host Name d0ol20:55513 State=up
> 33358 bytes allocated
> MUO_PROC_23/FD(0r-) MUO_PROC_23/FD(0rw)
> MUO_PROC_23/MEM(0r-)
> MUO_PROC_23/MEM(0rw) MUO_PROC_23/CPU(0r-)
> MUO_PROC_23/CPU(0rw)
This indicates that your client side application has created multiple channels
for the same PV name.
> Does this indicate a problem with our channel access client?
This certainly indicates that there is room for optimization. Whether this is
necessary or not will depend on your situation - how many channels, how often
this gets used etc.
> What is the key for the code following the record names?
This is documented in the ADG.
The entries all take this form.
pvName(nnnn{r,-}{w,-})
Where the nnnn indicates the number of monitor subscriptions attached to the
channel. The {r,-} indicates whether there is or isn't read access. The {w,-}
indicates whether there is or isn't write access. Sorry about the cryptic code,
but compactness seemed to be appropriate when printing a list of channels (which
could be long).
Jeff
--- Begin Message ---
Title: multiple identical names from casr 2
EPICS R3.13.4 we usually see the same name listed multiple times. Here
is an example.
Client Name="bartlett", Client Host="d0ol20.fnal.gov", V4.8, Channel Count=6
Does this indicate a problem with our channel access client? What is
Thanks
Geoff
--- End Message ---
- multiple identical names from casr 2 Geoff Savage
Problem with static build on Linux solved Mark Rivers
RE: dynamically remove PV's from excas? Jeff Hill
<2003>
2025
2026
puzzling "Record Type does not exist" message Michael Borland
<2003>
2025
2026
