1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: [Fwd: Re: Does DISP work for DB OUT links? Related question]
To: [email protected]
Date: Thu, 4 Sep 2003 11:49:04 +0100
In general, for analogue output it does seem that
caching is probably the best way forward. However, there are
situations where queueing rather than caching would be required.
eg:
An mbbi output requesting processing through a sequence of states
   this could be as simple as a device that needs to be switched
   off the on again in oreder to reset it.
Taking backlash off a motorised component.
   or any other device where a transient peak was required.
Perhaps some mechanism similar to the deadband used
in ai records could be used to discriminate.
Pete.
Prev: access control in cas Benjamin Sailer
Next: Re: DM to EDM conversion tools Joan Sage
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Fwd: Re: Does DISP work for DB OUT links? Related question] Benjamin Franksen
Next: Home signal does not affect the .ATHM field of the motor record Rok Sabjan
