1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: The EPICS record field base attribute
To: tech-talk <[email protected]>
Cc: "Savage, Geoff" <[email protected]>, "Bartlett, Fritz" <[email protected]>
Date: Tue, 09 Sep 2003 12:08:58 -0500
  The field definition for an EPICS database record allows for the
specification of a base radix with the syntax:
	base(<base-type>)
where <base-type> can be DECIMAL or HEX with DECIMAL the default, c.f.
"EPICS IOC Application Developer's Guide"; Release 3.14beta1; page 67-68.
  I would interpret this to mean that any numeric value assigned to this
field when defining an instance of an EPICS record would be interpreted
according to the designated (or default) base radix. This does not, however,
appear to be the case.
  Here is a field definition from a .dbd file:
          field(BADR,DBF_ULONG) {
                prompt("VME base address (hex)")
                promptgroup(GUI_DISPLAY)
                base(HEX)
                interest(1)
                initial("0")
and here is an instance of a record definition in a .db file:
          record(vme,"TRG_CSEQ_M001/NXTA:R") {
                field(DESC, "CSEQ Next Address Read")
                field(SCAN, "Passive")
                field(BADR, "400000")
                field(ADDR, "0x8000")
                field(AMOD, "A24")
                field(DSIZ, "D16")
                field(RDWT, "Read")
                field(NMAX, "2048")
                field(NUSE, "1113")
                field(AINC, "2")
                field(ASND, "1")
                field(EXPR, "0")}
The value that appears in the BADR field is decimal 400000. If the value is
prefixed by "0x", i.e. "0x400000", the field value is hexadecimal 400000.
  Am I missing something?
									Fritz Bartlett
Re: The EPICS record field base attribute Marty Kraimer
Prev: EPICS to WAGO PLC using Ethernet MODBUS Ivan So
Next: Re: The EPICS record field base attribute Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS to WAGO PLC using Ethernet MODBUS Elder Matias
