1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Tornado 2.2 builds
To: Geoff Savage <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Mon, 22 Sep 2003 15:02:10 -0500
Geoff Savage wrote:
On the epics web site there is information on building with tornado. http://www.aps.anl.gov/epics/modules/base/tornado.php
The instructions for building with tornado 2.2 are:
"Base R3.14.1 should build on Tornado 2.2 without change (you do need to correctly set the TORNADO_VERSION_2_2 option in the configure/RELEASE file though)."
That file may be a little out of date, I haven't touched it for quite some time (sorry!).
What is the correct setting for TORNADO_VERSION_2_2?
There is no setting needed in recent R3.14 versions of Base. I'm not sure when that requirement went away, and right now I can't even see where it's used in the R3.14.1 configure directory.
The issue I encountered is that in Tornado 2.2 (VxWorks 5.5) the c++ header files have moved.
Are you having build problems or was that just an informational comment? The C++ headers are probably more compiler-specific than the C ones, and for the GNU toolset can be found in host/<arch>-<os>/include/g++-3.
Note that the g++ compiler should know the above location already, so you won't need that information unless you're building your own toolset. Dave Thompson's instructions for Linux produced a toolset that works for me.
- Andrew
There are 10 types of people in the world:
Those who understand binary, and those who don't.
Tornado 2.2 builds Geoff Savage
Prev: Tornado 2.2 builds Geoff Savage
Next: EPICS with Automation Direct PLC Tao Zhao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
