1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS with Automation Direct PLC
To: "'Andrew Johnson'" <[email protected]>, "'Tao Zhao'" <[email protected]>
Cc: <[email protected]>
Date: Thu, 25 Sep 2003 08:17:25 -0500
I suppose I should weigh in on this.  The Ethernet version of the Koyo
PLC's uses a variant of the DirectNet Protocol over the network. I did
some work on porting the SDK used by Host Engineering over to Linux from
a Windows environment.  This was Relatively straight forward and only
involved changing some socket code.  It does work and there are
beamlines using this
As part of their own custom code.
I'm not sure what the state of the documentation for this is now since I
Haven't worked on it in years.   I do remember that there was an
endianness issue in the code that kept it from working on big endian
machines without major tweaking.  I still
Have the code base and if someone wants to work on it, I'll get ahold of
Host to see if its ok to share it.  Let me know.
Cheers,
John
John Quintana                                  630-252-0221  (ph.)
Northwestern University                   630-252-0226  (fax)
Building 432/A001                           [email protected]
9700 S. Cass Ave
Argonne IL 60439
-----Original Message-----
Sent: Wednesday, September 24, 2003 9:31 AM
To: Tao Zhao
Cc: [email protected]
Subject: Re: EPICS with Automation Direct PLC
Tao Zhao wrote:
> I need to connect EPICS to Automation Direct PLC through Ethernet Base
> Controller. Have anyone done that? Would anyone recommand some online
> documentation for EPICS Device Support or Driver Support to read?
We are interested in being able to do this here at APS; we already
communicate with Automation Direct PLCs using their DirectNet serial
protocol, the software I wrote to do this is described at
    http://www.aps.anl.gov/asd/people/anj/directNet/
and the code can be found at
    http://www.aps.anl.gov/asd/people/anj/tar/directNetMpf1-0.tar.gz
It may be possible to re-use some of this software with an ethernet
connection to the PLC, in particular look at the device support routines
and the PLC status database.  If you can't reuse the code I would hope
that at least the hardware address format I devised could be used, as
commonality at this level will make it easy to move databases between
the
two device types.  See the above documentation for details of the
format,
it's simple and relies on named PLCs being configured in the IOC startup
script.
Note that the above driver uses Marty Kraimer's MPF and mpfSerial for
the
serial port handling.
I am willing to help with questions and more, but after today I'll be
away
on honeymoon for the next 2.5 weeks (yay!).
- Andrew
There are 10 types of people in the world:
Those who understand binary, and those who don't.
Re: EPICS with Automation Direct PLC Andrew Johnson
Prev: Re: record help Marty Kraimer
Next: RE: Highland DDG cards responsibility Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS with Automation Direct PLC Andrew Johnson
Next: epicsExportAddress Geoff Savage
