The release notes show that a change was made to mbboRecord >mbboRecord >Field VAL now has a cvt_dbaddr method. If any state strings are defined the >field type and dbr_field_type are declared ENUM. If no state strings are >defined then the type is USHORT. Previously the types were always ENUM. This change was OK. HOWEVER. At iocInit time the following happens: 1) init_record is called for all records with pass=0
2) All links except INP and OUT are resolved.
This causes the stringout record DOL link to be resolved.
3) init_record is called for all records with pass=1
It is during this pass that mbboRecord looks to see
if any strings have been definedSince DOL is resolved BEFORE the mbboRecord has looked for strings, the cvt_dbaddr of the mbboRecord sets the type to USHORT. The fix will be to make mbboRecord look for strings being defined during pass=0. Marty Kraimer Bill Cruise wrote: I'm finally getting back to my 3.13B11 to 3.13.8 upgrade and tackling all the interesting little problems introduced therein. This one is a bit more perplexing, so I'd like to ask about it before throwing a fix at it. I'll also present a simplified case, rather than the convoluted one in my system.
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
