1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: database expansion in R3.14.4
To: Tech-talk <[email protected]>
Date: Wed, 08 Oct 2003 16:39:33 -0400
I've been trying to expand a database at build time using a
substitutions file that uses several template files, named in the file.
It seems that whatever I do I can only get the command
msi *.substitution *.template > msi.tmp
to run, which uses the named template file in all template lines in the
substitution file regardless of the file named therein,  when really all
I want is
msi *.substitution > msi.tmp
I looked this up in the application developers guide and it seems to
agree that only the first functionality, which seems to only allow using
one template file per substitution file, is provided.
What am I missing here?  Did the 3.14 build rules really drop this
capability?
Carl
Carl Lionberger
SNS Control Systems Group, ORNL
Phone: 865-574-7636
Fax:   865-241-6739
Prev: RE: CA; data length before TCP level Jeff Hill
Next: Does Subscribing to Tech-Talk Work? Steven . Banks
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: database expansion in R3.14.4 Thompson, David H.
