Welcome :-) Just a quick answer to your first question: This is considered a "feature" (which also confused me in the early days). Data shouldn't be written out as a result of the widget losing the focus (which could happen accidentally). Instead, EDM (like dm2k in earlier days) expects you to explicitely 'commit' your modifications by hitting the 'Enter' key. If a text entry loses focus prior to you hitting 'Enter' your modifications are reverted (which can be annoying but is safer). EDM has no way to know about a relation between your 'Dial' button and the Text Entry. They are connected to two different PVs and EDM sees those as two totally independent entities. Regarding the segfaults: use a debugger and submit stack traces etc. HTH -- Till [email protected] wrote: I'm a new EPICS user and am in the initial stages of learning how to use it. I wonder if anyone could comment on some behaviour that I'm seeing in a small EPICS application I've just written. I'd be interested to know if similar things happen in anyone else's environment.
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
