Folks,
I am getting the following error when processing an EPICS "seq" record with CA links:
dbCaLink: A call to "assert ((epicsMutexLock((pca->lock))==epicsMutexLockOK))" failed in ..../dbCa.c at 757
Current time THU OCT 30 2003 18:48:42.968775352.
EPICS Release EPICS R3.14.4 $R3-14-4$ $2003/09/23 21:35:11$.
Please E-mail this message and the output from "tt (0x1558050)"
to the author or to [email protected]
filename="../../../src/libCom/taskwd/taskwd.c" line number=170
task 0x1558050 suspended
Here is the output of "tt":
ioc13lab> tt (0x1558050)
19e530 vxTaskEntry +60 : 1a70bcc ()
1a70c1c epicsThreadPrivateGet+cc : dbCaTask ()
19ff9e0 dbCaTask +2d4: epicsAssert ()
1a6f9dc epicsAssert +f0 : epicsThreadSuspendSelf ()
1a70644 epicsThreadSuspendSelf+14 : taskSuspend ()
value = 0 = 0x0
The problem happens when the following record is processed:
grecord(seq,"$(P)AbortScansSEQ") {
field(LNK1,"$(P)scanH.EXSC CA MS")
field(LNK2,"$(P)scan1.EXSC CA MS")
field(LNK3,"$(P)scan2.EXSC CA MS")
field(LNK4,"$(P)scan3.EXSC CA MS")
field(LNK5,"$(P)scan4.EXSC CA MS")
This record is just writing 0 to the "EXSC" field of 5 "sscan" records using CA links. The problem does not appear to be in the sscan record itself, because I can write to the .EXSC fields using CA from a client, or using "dbpf" from the vxWorks prompt, and it works fine.
Changing this record to:
field(LNK1,"$(P)scanH.EXSC PP MS")
field(LNK2,"$(P)scan1.EXSC PP MS")
field(LNK3,"$(P)scan2.EXSC PP MS")
field(LNK4,"$(P)scan3.EXSC PP MS")
field(LNK5,"$(P)scan4.EXSC PP MS")
i.e. using database links rather than CA links "fixes" the problem, and there are no errors.
I've attempted to reproduce the problem in a simple example application and have not been able to do so yet.
Any ideas what the problem could be?
- Re: Problem with dbCaLink task in 3.14.4 Marty Kraimer
flash bootrom failure Geoff Savage
<2003>
2025
2026
<2003>
2025
2026
