Marty wrote:
> Nothing obvious. The failure occurs on the statement
> epicsMutexMustLock(pca->lock);
> Other than memory corruption it is hard to explain why this fails.
> Does this happen the very first time $(P)AbortScansSEQ is processed?
Yes.
> Before it is processed issue the instruction
> dbcar "$(P)AbortScansSEQ",3
> Does it show everything connected?
Here's the output, everything is connected.
ioc13lab> dbcar "13LAB:AbortScansSEQ",3
connected ioc13lab 13LAB:AbortScansSEQ.LNK1 13LAB:scanH.EXSC
connected ioc13lab 13LAB:AbortScansSEQ.LNK2 13LAB:scan1.EXSC
connected ioc13lab 13LAB:AbortScansSEQ.LNK3 13LAB:scan2.EXSC
connected ioc13lab 13LAB:AbortScansSEQ.LNK4 13LAB:scan3.EXSC
connected ioc13lab 13LAB:AbortScansSEQ.LNK5 13LAB:scan4.EXSC
ncalinks 5 not connected 0 no_read_access 0 no_write_access 0
nDisconnect 0 nNoWrite 0
ca_client_context at 0x15baf50 pndRecvCnt=0 ioSeqNo=0
epicsMutexId 0x15bad58 source ../../../src/libCom/osi/epicsMutex.cpp line 196
Channel Access Client Context at 0x15a3cf0 for user iocboot
revision "@(#) EPICS 3.14.4, CA Portable Server Library Oct 6 2003"
preemptive callback is enabled
there are 0 unsatisfied IO operations blocking ca_pend_io()
the current io sequence number is 0
IO done event:
Semaphore Id : 0x15a6c90
Semaphore Type : BINARY
Task Queuing : FIFO
Pended Tasks : 0
State : EMPTY
Is the message about the epicsMutexId with the source code line number normal?
Memory corruption is certainly possible, but if I don't process that one record then the IOC runs for many weeks with no other symptoms of problems. The same record causes the same problem in multiple IOCs with very different configurations (records loaded, SNL programs running, etc.).
Re: Problem with dbCaLink task in 3.14.4 Marty Kraimer
RE: Problem with dbCaLink task in 3.14.4 Mark Rivers
<2003>
2025
2026
<2003>
2025
2026
