Manual for 3.14.4 is much better but I again have couple question
concerning CA.
At first, I would like to discuss 3.14 version and of course
ca_context_create( ca_enable_preemptive_callback);
1. So, first question about
ca_current_context () and ca_attach_context().
My program srars and I created thread ONE and use
ca_context_create (ca_enable_preemptive_callback);
Then I create thread TWO. I believe that I should use
struct ca_client_context * pSThreadCAContext;
pSThreadCAContext = ca_current_context ();
// pSThreadCAContext should not equal NULL!!!
int iStatus = ca_attach_context( pSThreadCAContext);
// iStatus should equal ECA_ISATTACHED
What is next step? For example,
pSThreadCAContext->ca_function( ...);
or
ca_function( ...)?
If I am not mistaken when I would like to finish work with CA I should
- close all channel in all threads
- use ca_context_destroy(); once in any thread.
Am I right?
Also what I will have if I init CA library some times?
And last not question - suggestion. Maybe CA library can be exist
without
this init level. When channel will be open CA library will init in first
time,
attach in other thread and so on.
2. ca_pend_io and ca_pend_event.
I have asked this question. But I continue misunderstanding ...
When I use ca_enable_preemptive_callback that CA library open its
thread.
So CA library has its CPU time. What background activities should CA
library do in CPU time of other threads?
3. Some time ago I understood that I open channel to PV's field. So each
PV's field has type, count, reading/writing access, host name
(why not IOC name?). Also channel to PV's field has connection status.
But what about timestamp? Is it only to VAL field?
4. And last question. What do client and server do when connection lost?
I believe that they are waiting up to EPICS_CA_CONN_TWO time and server
is sending beacons. But what is later? Does server clean resource of
disconnection channel? Why client can connect again if server was
rebooted?
Thanks in advance,
Andrei.
- RE: CA questions Jeff Hill
RE: Problem with dbCaLink task in 3.14.4 Mark Rivers
Question on newer MVME-177 Chestnut, Ronald P.
<2003>
2025
2026
<2003>
2025
2026
