Geoff,
I will only address the path issue, but not EPICS.
Using "sh" shell commands:
Example 1.
An absolute path (example: "/usr/local/epics/bin") is specifically
defined and works.
Example 2.
Also the following will work:
set EPICS_DIR = /usr/local/epics
set BIN_DIR = /bin
set $PATH = $EPICS_DIR$BIN_DIR
then:
> echo $PATH
/usr/local/epic/bin
So if you used $PATH, you would also get to
/usr/local/epics/bin .
Example 3.
Now if you add an external product (say in /usr/local/product/bin)
then you could:
set $PRODUCT_DIR = $EPICS_DIR$/../product/bin
and
> echo $PRODUCT_DIR
/usr/local/epics/../product
/usr/local/epics/../product is equal to /usr/local/product and would
work. But, there is more chance of error.
Just specifying set $PRODUCT_DIR = /usr/local/product reduces the
chances of making an error, especially when referencing a location
outside of your current location, in this case EPICS.
If this seems confusing, then maybe that was my point. Use the
simplest way that works.
Hope this helps.
Billy Adams
Geoff Savage wrote:
I have two environment variables that are set when I go to build a top
area, EPICS_DIR and EPICS_EXTENSIONS_DIR, in addition to
EPICS_HOST_ARCH. I want to use these environment variables in
configure/RELEASE to specify where the external products are located.
EPICS_BASE=$(EPICS_DIR)
SYMB=$(EPICS_EXTENSIONS_DIR)
VXSTATS=$(EPICS_EXTENSIONS_DIR)
With these definitions there are environment variables missing from
configure/O.solaris-sparc/CONFIG_APP_INCLUDE. For example when
constructing dbd files that include dbCommon.dbd the dbCommon.dbd file
is not found.
When I use absolute paths everything works. Would someone please remind
me why I need to use absolute paths when specifying products in the
configure/RELEASE file? Can I specify these variables in a different
location?
I'm using epics R3.14.4 on solaris-sparc.
Thanks
Geoff
Billy Adams <mailto:[email protected]>
Raytheon Technical Services
Assigned to: Research Facilities Branch of
Research Facilities Management Office
16 Victory Street Mail Stop 413
Building 1251, Room 126D
NASA Langley Research Center
Hampton, Va. 23681-2199
Phone 1-757-864-6242 Fax 1-757-864-8095
- configure/RELEASE contents Geoff Savage
building et_wish on HP-UX Bill Cruise
<2003>
2025
2026
Re: configure/RELEASE contents Benjamin Franksen
<2003>
2025
2026
