1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA performance
To: "'[email protected]'" <[email protected]>
Date: Mon, 10 Nov 2003 15:22:24 +0100
Has anyone carried out any channel access performance tests?, comparing
performance for instance between:
Different versions of epics
Different number of channels
Different data lengths
Different numbers of clients and servers
At the moment I am thinking of running a test varying the following;
Number of clients 1->8
Number of servers 1->8
Data length 1->1KB per channel
Number of channels per server 1 -> 100'000
Client connections per server channel 1->8
get and put requests
3.13 and 3.14 clients
Redhat Linux 7.3 and 9.0
All machines would be identical PCs running Linux, on an isolated network
(one machine will be configured with two network interfaces to give access
from the outside world). Servers would be 3.14. Network would be switched
100Mbit or Gbit Ethernet.
Any comments or suggestions?
Would anyone be interested in defining the tests that could be run and/or
participating in the testing (you would be able to login to the machines).
regards
Steve Hunt
RE: CA performance Jeff Hill
Prev: EPICS training Bob Dalesio
Next: Re: configure/RELEASE contents Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: CA performance Jeff Hill
